- 4 Oct 2019
- Queens Park - London
Hi all
I'm looking at watercooling my 3080 FE in the future and I've just done a google for waterblocks for it and they start at expensive and go to stupidly expensive.
I'm dumping a ton of heat into my chassis (specs in sig but it's an ITX build with a Q58 and a AMD 5700X) and I have 2 times 140mm fans extracting heat out the top for it.
A lot of the heat is just from the GPU so why not watercool it and extract the heat out the top via a rad?
I would, if I could, just get an AIO and a mounting bracket like the NZXT G12 and be done with it if it worked.
However, the G12 doesn't work with a 3080 FE unless you modify the bracket which I am prepared to do and several forums have raised the concerns that it doesn't properly cool all of the hot points on the GPU and just has a fan. That can be fixed with some copper heatsinks but not ideal.
A waterblock would be ideal for cooling but the whole setup is expensive. I would go cheap and not pretty - I don't really care about looks that much. Some soft tubing, a basic pump-res combo and a basic GPU waterblock would be fine.
Any suggestions? The below waterblock price is mental.
My basket at OcUK:
My basket at OcUK:
- 1 x EK Water Blocks EK-Quantum Vector FE RTX 3080 D-RGB Water Block - Black Special Edition (SKU: WC-A26-EK) = £249.95
Total: £258.65 (includes delivery: £8.70)
