Deleted User 298457
Deleted User 298457
I concede. OP went 36V and that is just too much for team red.
Hard figuresWill the VRAM be enough though??? - Paging @TNA and crew
I got one of those smart wifi power monitors:
And did some testing, I knew my PC was pretty efficient under normal browsing etc, but didn't have any hard figures to back it up, now I do:
unfortunately true, we've got the larger deluxe version with the cover and its overrated. It doesn't get plugged in anymore, not worth the money to run it.lol. About as useful as breathing heavily on your wet laundry to dry it.
He's great, turns inside out to become a grumpy octopus on bad daysI love the squishy octopus.
Am I missing something here?Will the VRAM be enough though??? - Paging @TNA and crew![]()
It's a long running gag in the GFX card forum where it has been disputed by a select few on whether 10GB of VRAM is too little or enoughAm I missing something here?
I'm only on 2560x1080 so twice the performance over my GTX 1070 will be fine for me![]()
That thing costs 7p per hour to run.Jokes on you as my sweats are now totally dry and were out the washing machine at 9am.![]()
Your heat pump tumble dryer was £700 thoThat thing costs 7p per hour to run.
Sounds like you've just had it running for 11 hours. That's 77p. A load in my heat pump tumble dryer costs about 51p.
I may be missing something, but those things aren't as cheap to run as they seem. 7p per hour sounds cheap but it's actually not really. In fact I own one, but just use it as a passive air dryer. Try not to leave it on overnight.
Literally half. And I can get clothes dry in 2 hours. And I have small kids so it's really useful when under the cosh.Your heat pump tumble dryer was £700 tho
Looks like a hell of a (plunge?) saw. What you going to use it for?How could I forget...
Impressive, if inaccurate psychic abilitiesYour heat pump tumble dryer was £700 tho
Smurf?
Plunge sawing stuffLooks like a hell of a (plunge?) saw. What you going to use it for?
Looks proper heavy duty compared to my cordless makita sawPlunge sawing stuff
Making a few of the kitchen cabinets (in-frame) for my O/H as she needs bespoke sizes. We've also got engineered hardwood floors to lay so will need to trim long lengths. And also some seating/cabinets in a dining area to build in too.
Using a circular saw with a long fence is a bit of a PITA and doesn't give reliably straight cuts, this will give a cleaner cuts with a smaller kerf and less waste. At least what I have isn't compatible with a track, nor really suited to precision work, isn't cordless or part of the teal army![]()
