If you undervolt a 13700k or 13600k I think you'll be absolutely fine aircooling. A 13900k.... That's stretching it and you're wasting some of what you're paying for, I feel you really need at least a decent AIO to get the most out of it.
The answer to your question is... It depends. I think if you're sensible, pick a chip with less cores that wants less power, you'll be fine on air. If you want a higher core count power guzzler, you'll either need to undervolt to drop temps and potentially lose performance that way (You may be lucky and get a good undervolter, or unlucky and get a bad one), or, lose some performance on an air cooler because it simply gets too hot.
Thanks for the links I'll have a read through later this evening.
13900K is beyond my budget and more than I need. A reasonable AIO looks the way to go. I don't think I'd have to think about under-volting a 13600 to keep things in check. Which for me is a good thing, the more things to adjust just opens the door on inadvertently getting it wrong.
I've just run through a couple of comparative builds and I'm surprised how close the total is. I'm sure I'll be chopping and changing for days yet. (I've only put a DVD version of windows in so I don't forget it cost it in) £1400 is right at the top of what I wanted to spend.
YOUR ORDER
YOUR ORDER
1 X AMD Ryzen
5 7600X Six Core 5.30GHz (Socket AM5) Processor - Retail - £319.99
SKU: CP-3DG-AM
1 X Asus TUF Gaming X670E-Plus (Socket AM5) DDR5 ATX Motherboard - £329.99
SKU: MB-6JA-AS
1 X Kingston FURY Beast EXPO 32GB (2x16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit (KF556C36BBEK2-32) - £199.99
SKU: MY-29U-KS
1 X Samsung 980 Pro 1TB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive - £128.99
SKU: HD-248-SA
1 X Phanteks Revolt Pro 850W 80 Plus Gold Modular Power Combo Supply - £119.99
SKU: CA-08A-PT
1 X Microsoft Windows 11 Home 64-Bit DVD - OEM (KW9-00632) - £127.99
SKU: SW-18J-MS
1 X be quiet! Pure Loop 2 FX 280 ARGB High Performance CPU Water Cooler - 280mm - £119.99
SKU: HS-025-BQ
1 X Lian Li Lancool II ARGB Midi-Tower Case - Black - £90.95
SKU: CA-77T-LL
1 X Seagate 2TB Barracuda HDD 7200RPM 256MB Cache Internal Hard Drive (ST2000DM008) - £49.99
SKU: HD-3A5-SE
Grand Total: £1,502.57 (Edit to 670E)
YOUR ORDER
1 X Intel Core
i5-13600KF (Raptor Lake) Socket LGA1700 Processor - Retail - £334.99
SKU: CP-6B8-IN
1 X Gigabyte Z690 UD AX - Intel Z690 DDR5 ATX Motherboard - £209.99
SKU: MB-5A9-GI
SKU: MY-29U-KS
SKU: HD-248-SA
SKU: CA-08A-PT
SKU: SW-18J-MS
SKU: HS-025-BQ
SKU: CA-77T-LL
SKU: HD-3A5-SE
Grand Total: £1,397.57
