Does any of the 4090's apart from the strix control the speed of the PC case fans ?
Caporegime
27 Nov 2005
Guernsey
Does anyone know if any of the other 4090's can control the case fan speeds like the Asus Strix gpu's do ?
Here a picture of the fan speed outputs on the strix (For anyone that not sure of what i mean)
Picture taken from this review https://www.techpowerup.com/review/asus-geforce-rtx-4090-strix-oc/3.html
Near the back of the card you'll find two fan headers that run the connected fans at the same speed as the GPU fans, including fan stop.
This makes it a great option to control the case fans according to graphics card temperature.
Personally I setup a custom fan curve using Argus Monitor to ramp up the case fans based on my GPU temps.
This is the way.
I use Argus Monitor to control the fans on my water cooled PC according to water temp and the fans on my air cooled PC according to GPU temp.
One licence covers two machines.
Yea OP, lots of models have fan headers like the Strix
But in reality, as others have said it's a poor choice same as using bios fan control. There is just one piece of software called Argus Monitor and once you have it you'll never need anything else
