This is strange.
Set it to favour quality with high frame mode on and I’m hitting 118fps
Set it to favour performance and I get 78-80fps.
This is on a LG C2 oled so I can check the fps by bringing up the game optimiser screen or mashing the green button on the remote to bring up a small fps box.
Anyone else finding this glitch?
I'm on a C2 as well, that's probably normal because you need the TV to refresh at 120hz to force 40fps, the frames have to divide evenly into 120hz as each frame is tripled and what's being shown is not the actual framerate but the current refresh rate of the TV, it's not really accurate anyways. VRR adjusts the refresh rate of the screen on the fly and it does it quickly. With Performance HRF + VRR your screen should refresh anywhere between 60-120hz on the fly.
With the game targeting 40fps, the screen refreshes at 120 and each frame is tripled, 120÷3=40.
Pretty sure that's what's going on, will check later. The refresh rate should still fluctuate with 40fps unlocked but the optimiser doesn't show this correctly, most likely.
