new build
20 Aug 2009
co tyrone
hi all i need to replace
a few old parts with your help.
the motherboard is a oem b75 (socket 0)
chip intel core i7 2600@340ghz
psu vs 500/500w
ram ddr3@ 665mhz.
parts im keeping are gpu nvidia geforce gtx 1650
sata hdd case mouse keyboard monitor is 4k tv
he plays rallycross racing games
thanks for any help not too expensive if it can be done
you haven't told us your budget
in any case, i suspect it isn't much and as such, would recommend buying used and getting something like an intel 8400/9400, or ryzen 3600 build
you have access to members market, so definitely doable for less
ryzen 3600 £70-80
cheap cooler £10-20
b450 mobo £40-50
16gb 3200mhz ddr4 ram £35-45
good quality 500-600w psu £25-35
you may or may not need to change the case depending on the motherboard
ryzen 3600 £70-80
cheap cooler £10-20
b450 mobo £40-50
yes will look into that thanks, was hoping for new but.
Going new.
My basket at OcUK:
Total: £402.86 (includes delivery: £0.00)​
Your case needs to be ATX size and be able to take a 155 mm cooler or bigger otehrwise you will need to change things.
If you can push a bit more I would buy the better 5600 chip for £39 more.
My basket at OcUK:
Total: £139.99 (includes delivery: £0.00)​
The motherboard has bios flash without cpu by the looks of it so if it doesnt hav ethe correct bios on it its no issue to just connect it all up and do a bios flash.
£100 (incl. VAT)
£62 (incl. VAT)
£100 (incl. VAT)
£90 (incl. VAT)
£170 (incl. VAT)
£90 (incl. VAT)
FREE DELIVERY
psu vs 500/500w
ram ddr3@ 665mhz.
Umm, is he playing at 4K?
If so, you're probably keeping the wrong part :o
