Yup, always handbrake & neutral unless I know the lights are about to change. Along with being courteous to the driver behind, it also helps prevent hitting the car in front if you get bumped from behind or your foot slips off the brake/clutch
This. I sometimes pop the electric handbrake on to stop the brake lights from blinding the person behind, but only if I know it's a long phase, or I'm stuck in traffic which isn't moving, etc.My car automatically applies the brake lights when stationary and using the auto hold function. I have no choice about it. I'd imagine almost all modern cars are the same.
More or less - depends a bit on the drive type/tech used. Putting it in and out of park from drive will also illuminate reverse lights briefly which tends to panic or confuse people behind.
Yes, at night especially so the LED brake lights aren't burned into the retinas of whoever's behind me. It'd be nice if others would return the favour but it rarely happens.
Often combined with a rear wiper on a dry dayWhat's worse is rear fog lights! I'm now behind you, I know you are there, please turn the damn thing off!
Not on most modern auto boxes surely? They don't look like this any more! P is now just a button on the side/top of the lever.More or less - depends a bit on the drive type/tech used. Putting it in and out of park from drive will also illuminate reverse lights briefly which tends to panic or confuse people behind.
Auto hold in my VW, no idea if the brake lights come on actually!
On another note does anyone ever put their auto into N? Can't remember ever using it, just D, R and P...
Park locks the box, you still have another hand brake.automatic car
Never put your car in "park" before it stops completely
Don't put it in "neutral" at stop lights
this is what i heard (looked it up now)
So does this mean putting in "park" is the hand brake on auto boxes ?
Why should you not put in Neutral![]()
