anything more than a couple of years old or so will have a lever like that.
My 2010 5 Series didn't and neither does my 2015 5 Series.
Neither did my 2013 3 series.My 2010 5 Series didn't and neither does my 2015 5 Series.
Sitting low in the MX-5 is a constant reminder of how annoyingly blinding brake lights are at night when sat in traffic.In my manual MX5, yep, regularly use the handbreak. In the automatic BMW, nope.
I've dismissed a couple of cars I've looked at with the electric parking brakes. Awful things.Vast majority of brands only relatively recently moved away though, some cheaper vehicles still do use the old style shifter and probably will for awhile yet.
Personally prefer it TBH not a big fan of the electric parking brake either though I can live with it.
Unfortunately I suspect that electronic handbrake will eventually be standard on everything. That said I don't really have any issues with them as they normally Auto engage and disengage, so should be easier for normal use.I've dismissed a couple of cars I've looked at with the electric parking brakes. Awful things.
I think you're misunderstanding here - I'm not referring to the lack of a shifter, which I agree is a reasonably new thing. But it's been many years now since most cars with a shifter had it physically connected to the gearbox. It's just a switch which controls the gearbox electronically. Consequently, you don't pass through reverse to move from Park to Drive like you would in a much older gearbox as Park is selected either by pressing a button or automatically if you switch the engine off. I doubt most people ever select Park themselves anymore.Vast majority of brands only relatively recently moved away though, some cheaper vehicles still do use the old style shifter and probably will for awhile yet.
This isn't new, or even that recent.
The 8 speed gearbox used in various BMW, Audi, even vans has been around for more than 15 years and is fully electronic, even the later versions of the previous 6 speed model had electronic shifters. The same is true of many other manufacturers - I cannot remember the last time I drove an automatic that had a gear shift that was physically connected to the gearbox itself. It certainly wasn't on a car registered this side of 2010. There will doubtless be some, I agree, but they are very much a minority and will be very dated cars.
Pretty much always, I had some people comment recently how often I use it. Which shows most people just sit at the lights with their foot on the brake.
My truck will select neutral after a few minutes of it being stopped, it’s an automated manual transmission rather than a conventional torque converter design mind you, it has no park position as such.automatic car
Never put your car in "park" before it stops completely
Don't put it in "neutral" at stop lights
this is what i heard (looked it up now)
So does this mean putting in "park" is the hand brake on auto boxes ?
Why should you not put in Neutral![]()
