- 26 Sep 2022
- Usa
My system: i7 12700kf - 360mm AIO liquid cooler, 64GB DDR4, etc.. my case is an open frame Thermaltake Core P3 TG. My system is not overclocked. It does not overheat. I've got temps displayed on my Stream Deck.
Last night I picked up an XFX Speedster SWFT309 RX 6700XT 12GB. I run it on dual 32" 1440p monitors @ 165hz. I had to install it with the PCIe riser because it didn't fit due to the larger radiator. Unfortunately I am stuck with the PCIe riser cable that came with the case, which is only 3.0. I can't afford a 4.0 right now.
I encoded some video as a test in Premiere, and I played CSGO. Seemed to work fine.
I come home tonight and there's stuttering in CSGO. I didn't think to check temps while I was in game, once I got out I noticed it's running hot.
I have MSI Afterburner. What are some settings I should do in there to help the temps out?
I did adjust the fan curve.. right now it's at 76% fanspeed and 33 degrees celcius.
What kind of other settings should I try?
Some people dream of those low temperatures!
Your temps seem almost too low, are you sure nothing is holding your GPU back?
