Hi All, wondering if any car gurus can help identify a strange sound.. Background is that this is a new to me car (2019) so i don't know what is normal and what isn't and want to get back to them quickly if it isn't right.
I have this almost arcing/electrical sound coming from the engine but i can't really pin point it. The sound starts when the car "wakes" up. ie i open the door or put in the key in ignition without turning it. Or for a bit after i've turned it off the engine and removed the key. I do not know about when the engine is running as its hard to hear over the noise.
There is also another type of noise thats more like a hum which i'm not bother about as it sounds like normal operation. The electrical sound seems come and go with the hum but is offset by a few seconds when the both disappear.
"Electrical" sound
voca.ro
Hum (you can still hear the other sound in the background, not bothered about this one, only really putting this here for completeness as these are the two noises its making)
voca.ro
"Electrical" sound
Vocaroo | Online voice recorder
Vocaroo is a quick and easy way to share voice messages over the interwebs.
This won't set your pants on fire but for reference its a Vauxhall/Opel Combo Life with the 1.2 petrol (PSA group car so is effectively the same as Citroën Berlingo, Peugeot Rifter). Having trouble finding out a proper fuse box diag, owners manual is useless. The engine compartment box for the Corsa F is the same layout and matches with the few fuses listed in the owners manual so i tried pulling various fuses from here to see if the device would turn off
