- 2 Sep 2013
OK, so I've got the Asus Proart X670E incoming, and it's a dual port ethernet motherboard, 2.5gb Intel and a 10gb Marvell Aqtion. Whilst I haven't upgraded the networks main switch to above 1gb yet (or have another device for 10gb yet, the Synology ds923+ is not available to purchase in UK just yet), I have seen that there's a QNAP 6 port switch that offers 2x 10gb and 4x 2.5gb that I can swap in for the gigabit switch I've got in place right now.
So I wanted to check in with everyone on which nic to use from the motherboard, the 10gb one? Or the 2.5gb one?
Logic would suggest the 10gb will have the greatest bandwidth, but I'm wondering (since I'm going to be gaming a might bit more than needing a large throughput to transfer files; for now at least...) if the 2.5gb one might actually be the faster one for gaming? And actually should be the one that's used for gaming and internet? In my particular case, if I do grab that QNAP 10gb + 2.5gb switch, the new rig will end up using the 10gb port on the switch anyway, just going from the 2.5gb on the motherboard if it's the better one to use instead.
I do suppose that it's just a quick port swap with the cat6 ethernet cable if it was slower to use the other one, but just wondered if there's an obvious answer to this or not that I'm not seeing.
Thanks all for any info on this.
