Hi!
I recently won a Lenovo IdeaPad Flex 5 through a promotion at work, however, it has a smaller SSD than I would like, I think 500GB. Therefore, I would like to install a larger SSD, at least 2TB, possibly 3TB. I don't know if there are restrictions on what a laptop can support.
With Black Friday/Cyber Monday upon us, it seems like a great time to purchase the components. Would you good people be able to recommend which drive would be best/cheapest, and any other items I would be advised to upgrade? I have a friend who solders and welds for a living, so that should not be a problem to install.
The only caveat I would make is that I don't know PC components very well, so while I know there is a difference between SATA and NVme for example, I don't know which system takes which part, so please put full names of components or link directly, as I may not grasp fully obvious terminology. My max budget is probably £500, but if it is a crucial fix, I could go over it!
Also, as I would be replacing the SSD without having ever turned on the laptop, what would I need to load on the new SSD to make the new laptop work, and how would I do that, please? (as I said before, very new to this, please don't be afraid to overexplain/condescend, I'd rather understand).
The identifiers of my model are:
PLATINUM_GREY
IdeaPad Flex 5 15ALC05
Model name: 82HV
NB IP flex 5 15ALC05 R7 16G 512G 11h
Thank you in advance!
PLATINUM_GREY
Model name: 82HV
