3060 Ti or 3070
13 Feb 2011
Woodsetts
Hi All,
I'm currently running a GTX 1070 & have an urge to upgrade my Graphics card - what would be the best Bang for Buck on either a 3060 Ti or 3070.
Usually play Dayz, Tarkov & Squad - Current Specs are Ryzen 5 5600X, MSI MAG B500 Tomahawk, Crucial Ballistix 16GB.
Thanks in advance.
6700xt at £400 or 6750xt £420 is ok alternative. Not sure the 3070 is quite worth the extra. Nice to have available choices though - how things change!
Not really looked into the AMD Alternative - are they as buggy as people say - or has the Driver issue been sorted now?
the drivers are no more "buggy" than Nvidia and in many ways AMD's display panel is better than the Nvidia one. If you read both driver threads both state issues depending on your setup. eg Nvidia one recent release didnt downclock the GPU after running an app/game. I wouldnt base your GPU decision on just the driver.
With regards to 3060ti the FE is a really good card. Undervolt/overclock and it not only runs cool but can just about equal default 3070 clocks. (I had both)
Undervolting/overclocking in Afterburner?
