Ok. Thank you for the reply.Nope.
Product shall be made available as and when we have stock after NDA lifts. Stock shall be limited.
Can you say when the NDA is to be lifted Gibbo or is that part of the NDA?Nope.
Was hoping the supply would be decent.Nope.
same here missed out with the 6000 cards when they came out because of poor supply so decided to wait till this gen to finish off my rigWas hoping the supply would be decent.![]()
NDA probably lifts on the day and at time that the cards go on sale.Can you say when the NDA is to be lifted Gibbo or is that part of the NDA?
So how does it work exactly?NDA probably lifts on the day and at time that the cards go on sale.
Does the retailer get stock in before 13th December launch?
Or on December 13th, the cards are released from the manufacturers to allow the retailer to buy stock in from companies like Sapphire, asrock, etc?
Not sure why people are panicking over launch day stock, it's not the same as 2 years ago so if you miss out at launch day then don't sweat it since in a month or two the shelves will be full and you can pick n choose which card you want.
As I said if you give it a couple of months and there will plenty available and you get a chance to check out the individual card model reviews rather than panic buying on day one.It's an AMD launch, low numbers are expected. I wouldn't be surprised if the whole of the UK got a 3-400 spread around all the retailers. High stock levels and AMD launches do not go together.
I think it's just the anticipation for some folks who want to be at the cutting edge of the latest technology.As I said if you give it a couple of months and there will plenty available and you get a chance to check out the individual card model reviews rather than panic buying on day one.
I thought they supplied Xbox and PlayStation with their GPUs?AMD barely make any cards, maybe they should sell that division to Samsung or whoever.
if you say limited you can put prices higherWas hoping the supply would be decent.![]()
