- 21 Oct 2011
- ST4
Pair of gloves.
Don't forget to put a screen protector on it.
Ah the IPS screenBought a modded GBA. Going a bit retro with my gaming all of a sudden.
Love the light shade but can't help but think I'd get frustrated with the shadow pattern I'd it's a room you'll use regularlyFitted a new light - used wago's to tie off the old connected loops for other lights on the ring
Bedroom, I (currently) think it's pretty cool but I get what you meanLove the light shade but can't help but think I'd get frustrated with the shadow pattern I'd it's a room you'll use regularly
Incoming, heart shaped waterbedBedroom, I (currently) think it's pretty cool but I get what you mean
That looks a really tidy paintjob!Fitted a new light - used wago's to tie off the old connected loops for other lights on the ring
Are you planning on some side/table lamps tocomplimentsee your way about by?
The wife's had the kitchen done in some sort of burnt orange, I suspect to make it so dark her burnt offerings go unnoticed
My new generator arrived yesterday, but sadly only after being dropped off the couriers fork lift truck. "Do not fork from this end" is obviously too complex an instruction, and it's now back at Meccalte for a new alternator and control box....
The giveaway was the top box which left Meccalte secured with 4 rubber bolted bobbins to the alternator arrived here fully wrapped in bubble wrap and cling film where the couriers had tried to hide the damage. Plus CCTV showed it falling off the fork lift truck then disappearing back inside the warehouse for an attempt at hiding the dirty deed.
How are you finding the drying speed? I have a mate who got one (off a recommendation from me as we are looking at them too) and he hates it, takes 3 hours to dry a small load. That LG is the one we are thinking of buying so would love to hear some feedback.Got a new heat pump tumble dryer, amazed how quiet it is compared to the previous one.![]()
I've only done a load of bed sheets in it, was around half full and it took 2h20 I think. I knew it would be longer than our old condenser however I also know it's going to use much less energy, and be kinder to fabrics. The comparative quietness is an unexpected bonus.How are you finding the drying speed? I have a mate who got one (off a recommendation from me as we are looking at them too) and he hates it, takes 3 hours to dry a small load. That LG is the one we are thinking of buying so would love to hear some feedback.
It does have a sensor.Look for Dryers that use some form of sensi dry, so they stop once it's dry, if I do a small load it is done in less than an hour
Probably more expensive, venting outside isn't really an option for us due to placement.I hadn't heard of heat pump dryers so Googled them. Drying times all seem to be compared to condenser dryers though. How do they compare to conventional outside vented dryers, time and cost to purchase wise? Thanks.
