- 14 Jul 2005
- Birmingham
We don't know how big his house is. If its a typical UK 3 bed, then yeah I think there is no need to spend all that money adding huge CUs, patch panels and extra wiring for the minor inconvenience of running an extension lead out the door from time to time. It depends on his activities and lifestyle, and size of the place.So what you are saying is that because he has less space, things should be less well connected and thought through, for now and in the future.
Does he do those things though (he hasn't said). If you regularly work with power tools outside then sure, if not, run an extension lead for the couple of times a year you need it.Why is having outdoor sockets a bad idea? What has that got to do with the size of a house. If I want to plug in my pressure washer it goes in to an IP65 rated socket either at the front or back of the property, or if I want to work with non-battery power tools outside then I can plug them in safely without having windows and doors open.
What I was getting at with this one is why it needs a sparky to wire it? When you install the camera (presumably up near the roof eaves), drill a hole in the facia and run the power and cat6 into the loft right next to it. Why do you need to pre-wire that with a sparky?Why is Cat6 a bad idea for PoE cameras? Why have battery powered or mains powered cameras if you are having network cabling put in anyway.
Its a waste of money if it never gets used. If he is having a big media centre then sure, if its a normal UK living room then he probably isn't and a TV unit with the cables behind it is what 99% have got and its fine.Why is having cable run in a ceiling for future use a bad idea? Or would you prefer to pay someone twice to do the same job, the cable is cheap, the labour isn't.
Again comes down to size of property doesn't it? He hasn't said. The only thing you really need cat 6 for is for a PC gaming or file server. How many PCs is he going to have upstairs? I would say a file server in the loft is a pretty good idea, but can be run off a simple freestanding network switch box connected to the main router. If he's got a big house then he might need a wifi extender or 2nd network upstairs, but again only one ethernet point would be needed to connect that to the main router.Why wouldn't you have a patch panel somewhere if you are using Cat6 in the house, what is wrong with a loft space?
Sounds like your 'utility room' is bigger than the rest of your house to have that lot in it. I live in a typical UK 3 bed small house - it doesn't even have a utility room. It has a kitchen, and a hallway, and a combi boiler in the kitchen.I have a plant/utility room in a 'small' house - it contains the CU(s), solar PV/house inverter, house batteries, and other electrical switching, all network gear (sans modem for now), all the gubbins for hot water storage, water tank, and the control area for my soon to be fitted heat pump, it has the washer/drier and a sink on the plumbed side
Never had a house rewired, the most Ive done is added sockets in bedrooms, converted singles to doubles, and added outlets in the kitchen for appliances. Ive got a NAS, its next to the router. If I was to move it into the loft I'd just run an ethernet point up the outside wall and into the eaves. Simple.The costs to implement aren't great if it is though out in advance, and it allows a much greater scope in your property. May I ask when the last time you had a property rewired was, or indeed did it yourself?
