New Gpu or new system?
28 Nov 2022
New Zealand
Hi all, long time lurker first time poster from one of the crowns flag planting phases (NZ).
Many thanks for providing such a great resource that is this site and its members.
I'll get to the point quickly so you can get back to soccer.
I have a hybrid system made up of bits of my old system (GPU) and a newer system (The rest) I built for Dads business that he forgot about when he fell in love with his Surfacebook.
i7 8700 @ 3.20GHz 29 °C
32.0GB Dual-Channel DDR4 @ 1599MHz (16-18-18-36)
ASUSTeK COMPUTER INC. PRIME Z370-A II (LGA1151)
NVIDIA GeForce GTX 1060 6GB (Gigabyte) 34 °C
Samsung SSD 970 EVO Plus 1T (OS) + Samsung SSD 860 EVO M.2 1TB (Storage)
RM550X V2 550W Power Supply 80 Plus Gold Fully Modular
I mostly play space sims and RPG's like Witcher, Star Wars Empire at War (AOTR Mod) and anything with Big stompy Robots (Mech warrior, BattleTech etc)
I can play most of my games in 1080P at High settings but I am increasingly starting to find games that are pushing my FPS below 60 or my settings to medium.
This system gave me 60+ FPS at 1080 at High for about 5 years (with a swap from 6700k and 16gb in the middle part)
All I want is an upgrade so my system can do the same BUT with 1440P at 60+fps for a few years.
Is a simple upgrade to a 3070 going to be enough to accomplish that? (If so would it just slot in with my current mobo etc with no problems?)
If not what else do I need to add?
P.S. I hope this is in the right section as I didn't know if General or GPU section was most appropriate.
There's some legs left in it for a GPU upgrade, yes. I think a 3060 Ti/RX 6700 and up will give you a big performance jump @ 1440p compared to the 1060, but if that's a non-K CPU running at stock then it will be holding them back a bit, depending on the game.
Yeah, it is a non-k. What would u recommend then if I was going to upgrade the CPU? a newer intel or scrap this MOBO and get a new one with some sort of Ryzen?
Sorry if a mod sees this could they please move the thread to the "New to PC gaming and Upgrade Advice section"
I should have put it there in retrospect.
From what I've seen, used 1151v2 CPUs are still silly prices, so I'd go 12/13th gen (if you want to keep your RAM, which you might as well), but for now I'd just go with the graphics card upgrade.
