- 27 Jan 2009
- Oxfordshire
I saw these but also articles saying they’re not “to code” which put me off a little. Probably fine otherwise why do they exist, but will see if I can tackle the root cause first. It’s a new issue I think as the loft boards and beams don’t show any water damage apart from these new drips and I’m not sure when the previous owner added the extra insulation.You can also put these roof lap vents in the roof felt which may assist
Check this out! https://amzn.eu/d/0LEwzgQ
Used solder ring couplings and elbows with a small top-up and then a push-fit coupler to the existing pipes to avoid melting any of the nearby wires. Tested for leaks on a temp fitting in the kitchen for peace of mind. Petro tape (and gloves) to lag the sections in the wall which will be plastered over.
