- 4 Aug 2007
- Wilds of suffolk
do folks have to change (octopus) contracts during winter months away from preferential feed in ones, to the agile ones potentially giving lower off-peak battery recharge ?
Why would you do that right now if you are on go or similar.
Charge overnight at 7.5/8.25 unless really recently signed up.
Agile practically never hits that price point right now
Plus if you come off go and the guaranteed pricing you run the risk of not being able to get back on it.
The potential time to go onto agile is the summer when you can potentially benefit from the outgoing price being significantly higher than the capped price you are allowed when on go.
Octopus even say the reason they stick to the low outgoing price when on go is that you have such beneficial incoming pricing.
I may consider coming off go around April, my pricing is fixed to end of Sept. Its a gamble though.
Really need to see if any of the other companies start to try to challenge Octopus for cheap off peak since right now none are even close.
