- 4 Aug 2007
- Wilds of suffolk
So I need to trim some in place deck boards due to a garden redesign. One end is open so I dont need to plunge into the boards I can start level and just cut straight across.
I was thinking of getting a mini circ saw, then a mid size and now thinking full size.
Ideally I would go battery operated as it would potentially be quite handy at the allotment at times. Which is why initially I was thinking the mini one since I would use it for cutting small timber, sheeting materials etc at times.
But the depth of cut looks close to what I need, many saying 27-28mm which I think is the depth of the deck boards so might not be fully cut through, hence the though to go to 115mm blade side (mid size) for a up to 45mm or so cut depth
Now the considerations are, I already have a compound mitre so I use that for significant cutting and I don't particularly frequently cut sheet materials.
Although I am going to be doing some stuff with 18mm ply early next year, and I am talking trimming large 1.2x2.4M sheets. So a circ would certainly help there.
Now as far as batteries go, I am more leaning to cordless here as I said can take to allotment if needed. I have bosch blue and green both 18v already.
Are the large circ saws (180mm or so blades) much more unwieldy than say a mid size one, (115-120mm blades)
Last thoughts, I can hire at 95% discount from the trade, so I can hire top notch gear for a couple of quid for the weekend. (I often dont pay at all but thats the contract price if I have to pay), I would need to buy my own blade but then I can keep that anyway.
Should I not bother buying one and just hire, or is it a tool I will use more than i am thinking, and if so would say a bosch pro item like https://www.amazon.co.uk/Bosch-Professional-Cordless-Circular-Included/dp/B072J25TPG/ref=sr_1_1_sspa?crid=1E79C5IU4AWFD&keywords=bosch+pro+circular+saw&qid=1670408381&sprefix=bosch+pro+circular+saw,aps,60&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
be worth buying over a green https://www.amazon.co.uk/Bosch-Cordless-Circular-Without-Battery/dp/B00E5Z0DX0/ref=sr_1_22?crid=1E79C5IU4AWFD&keywords=bosch+pro+circular+saw&qid=1670408422&sprefix=bosch+pro+circular+saw,aps,60&sr=8-22&th=1
Looking at half decent others it will cost nigh on the same so as I already have the batteries for these it seems pointless to bring in a cheaper brand tool just for the fact its already got a battery etc.
I must say I am leaning towards the green here, but convince me I need to g blue if I should be buying
Any thoughts suggestions etc welcome
