Man of Honour
- 5 Jun 2003
- Falling...
Not particularly hopeful on g2. Now being told earleirst delivery is Feb so expect it will be more like April.
Sounds about right unfortunately
Yes, the extra kW is pretty big - if you think in terms of your battery size (I've got 19.5kwh), so the max a gen 1 could fill up is 2.6 x 4hrs for, say, Octopus Go - so 10.4kwh per night. With gen 2 @ 3.6kw, that becomes 14.4kwh.
If you then work out how much that adds up to as a difference over the year, it's not insignificant! (ie around £440 a year saving)
Yeah agree - unless your supplier will do this (quite a few are given the delays) - would definitely wait for a Gen 2. My installer has fitted gen 1 and I'll get 2 x Gen 2 fitted in End Jan/Feb. Supply has been very strained, but I do think there's a large shipment arriving in Jan, hence relatively confident supplies will improve somewhat....! (famous last words...!)That’s great info, thanks! A Gen 2 hybrid inverter is roughly £1500 so it’s probably not worth installing a Gen 1 now only to switch it out with a Gen 2 very soon afterwards.
My SMETS1 meter hasn’t been updated by the DCC yet so I’m not in a massive rush to buy a system, but at the same time it’s a gamble as to whether prices will rise and stock levels will get worse.
And it is quicker to respond to house demands, meaning less peak energy pulled from the Grid.This basically, and you can wire it up to ethernet rather than wifi. More modern hardware too etc..
Large hammerWe have 3 triangular dormers at the front of the house (which are purely for aesthetics) that are getting in the way.
PRaying for a dead inverter right nowAnd it is quicker to respond to house demands, meaning less peak energy pulled from the Grid.
Guys come out, dead inverter, said needs full replacement and showed me the boards burnt out in a number of places. Said likely Gen 2 replacement when they can get them! :S
Could be waiting a while, guess your main issue is you can't charge for cheap so expensive electric until it's done?
At least it failed without setting fire to your house. I could really do with getting some kind of fire extinguisher for the various electronic things I have kicking about. Fire risk is low but if it burst into flames I'd have no way of stopping it![]()
I have a couple of these, best price I could find at the time and came next day.
Needed some reassurance if it went **** up when building my batteries in the house.
PREMIUM REFURB 2KG CO2 FIRE EXTINGUISHER, FULL, HORN & BRACKET,FREE DELIVERY! | eBay
Find many great new & used options and get the best deals for PREMIUM REFURB 2KG CO2 FIRE EXTINGUISHER, FULL, HORN & BRACKET,FREE DELIVERY! at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Still on my old rates fixed until next year so not charging overnight currently.
@Troop 5months...
Will just levae them to sort, i'm not missing out on huge amounts of generation or cost implications currently, so long as it's done early in the new year will be fine, providing it's Gen2![]()
Givenergy, guy said his first failure logged not OOTB was this morning elsewhere.What make? Sorry if you posted above already.
