GOOD Win10 driver updater ?
5 Jul 2007
Came across a driver updater the other day yet it was rubbish, false positives, some 'updates' didn't work at all etc. Today noticed on the ASUS motherboard website there was a LAN and Chipset driver update so downloaded them, just a flash on the screen then nothing. What software is out there that properly detects and installs driver updates, if any ?
Thanks in advance
None. Even the ones on the manufacturer site is usually out of date.
Bare in mind you don't have to try keep all your drivers up to date. The only one I bother doing these days is GPU, even then I only check every couple of months. Chipset as well sometimes. And I usually go directly for the drivers (AMD, Intel, Nvidia, etc).
Ccleaner pro is good. The licence has recently been £1 for a years licence. Ran it once and it updated several random drivers and all been good.
Half decent isn't decent.
This, 100%. And if you must update drivers, find them yourself.
It's a figure of speech but sure. It does a good job of keeping on top of the majority of drivers. GPU and Chipset drivers are pretty much the only thing I ever download manually.
Get chipset driver from Intel or AMD
LAN driver from the LAN manufacturer
GPU from Intel/AMD/Nvidia
If you have any gaps in Device Manager, hopefully Windows Update will sweep up the rest. If not, then go into the device in DM and find the hardware ID, Google this and find the device in question. Likely exists on motherboard manufacturer site.
