Hi all. Bay roof and ceiling replaced and wanted to ask on here some of my concerns before builders sign off the job.
Just to give you some idea of the dimensions the replaced ceiling isn't a large area, it's around 4sq meters. My concerns are 1. Float and set was stated in the job but plasterboard was used which was covered with sand coloured plaster material which has dried milky white? Could be the light.
Plasterer instructs me only paint when plaster is dry, should be around 3 days
I don't know anything about plastering (or pretty much nothing about diy) but after some reading it seems float and set is for walls with brick and the work that had actually got done is dot and dab? Can a float and set be done on a bay ceiling?
2. The second issue is there is a curve where old and new ceiling meet. (I'll try to add an image later). Main Ceiling steps down into bay and that step has noticeable curve.
Sorry there is a 3. Is it ok to paint on this sandy type plaster? I thought the brown stuff was the base and the use finishing white plaster next then paint?
Any advice would be appreciated.
Cheers
Cheers
