Unable to erase Mac Hard Drive
3 Jun 2005
The South
I'm assuming you're using Disk Utility within Recovery if it's your main system drive?
Possibly a read-only volume/partition/container, that '69614' error isn't particularly clear on what the exact issue is, and sometimes a second try can work after rebooting back into Recovery. But typically you would select the drive, in your case "Apple SSD * Media", and click Erase which will erase the complete drive.
Alternatively, have a look at the command line 'diskutil' command which you can use within Terminal (again in Recovery), as there are options like 'deleteContainer' which you can use with the '-force' switch to forcibly remove volumes/partitions/containers etc.
I would strongly recommend creating a MacOS USB install drive (need at least a 8 or 16GB drive) that you can boot from beforehand in the event you completely nuke the drive and recovery partitions with 'diskutil'.
smr
smr
OP
6 Mar 2008
Leicestershire
I'm not sure what the problem is with it - when the mac logs in, after a few seconds everything goes haywire and starts disappearing - you can see the icons on the screen but if you click on apps or utilities you can open something, and then all of the m disappear and the mac freezes with the spinning ball.
In recovery mode I have tried erasing the disk but it doesn't work.
smr
smr
OP
6 Mar 2008
Leicestershire
If I try just installing Monteray, from recovery mode, it goes so far, gets to 12 minutes remaining and says an error occurred loading the update.
smr
smr
OP
6 Mar 2008
Leicestershire
Looks like I'll have to bin this computer, just cannot get the bloody thing to erase. This is why I cannot stand Apple Computers, so unintuitive! On Windows it'd be a breeze to diagnose a faulty Hard Drive. Absolutely no idea which genius thought it was a good idea to spam drives with apfs containers and all that ridiculousness!
3 Jun 2005
The South
What model of iMac (assuming that from pics) have you got?
And what's the current MacOS version installed? Is it 12 Monterey?
I agree, Mac's can be a royal pain especially when it's drive related as you haven't got physical access to the drive.
What error(s) did it show when you attempted to erase the entire disk (using Disk Utility in Recovery)?
This is what diskutil shows. I just want to be able to format the drive and reinstall the OS. Any ideas ?
As said, if you can make a MacOS USB installer then do so as it's quite easy to bodge the drive.
But assuming you're using MacOS 10.12/10.13 (Sierra or High Sierra)+ and disk0 (double check with diskutil list beforehand) is your SSD/system drive, then try -
Code:
sudo diskutil unmountDisk force /dev/disk0
sudo diskutil erasedisk apfs "Drive Name Here" gpt /dev/disk0
Alternatively or MacOS is below 10.12 then -
Code:
sudo diskutil erasedisk JHFS+ "Drive Name Here" gpt /dev/disk0
Bodged partition table, look at the gpt command, or an issue with the T1/T2 firmware, can be revived but need another Mac, are other possibilities but i haven't personally experienced those so will require a bit of Googling.
And Apple Stack Exchange and/or the Apple community forum are worth a look as someone may be able to shed some light on the 69614 error.
  • Like
Reactions: smr
31 Dec 2010
Sussex
Are there not any bootable Linux's which the Mac can boot from so you can use GParted or similar?
Not knocking the CLI 'nix tools but nothing wrong with the GUI version. Bootable Linux's have always been my go-to when faced with stubborn drives, or drivers which won't load on PCs and as long as you can get similar for am x86 Mac that would be how I'd try this.
smr
smr
OP
6 Mar 2008
Leicestershire
Code:
Code:
Thanks for the reply. There isn't anything on the Hard Drive which needs saving, it's ok to format and install afresh - I did install Mac OS off a USB once, can't remember how I did it though - I think there was a website where you could download various Mac Operating Systems onto a USB and load them, would you happen to know?
It's Monteray, and it's an iMac (Retina 5K, 27-inch, Late 2015)
3 Jun 2005
The South
....would you happen to know?
If you've got access to another (working) Mac then -
Links for the MacOS Downloads - https://support.apple.com/en-gb/HT211683
How to create a USB installer - https://support.apple.com/en-gb/HT201372
On PC it's a bit of a PITA but -
Download MacOS DMG - https://techrechard.com/download-macos-monterey-iso-dmg-and-vmdk/#Download_macOS_Monterey_DMG_file
Alternatively you can try gibMacOS Python script - https://github.com/corpnewt/gibMacOS, https://manjaro.site/how-to-create-macos-usb-installation-disk-from-windows-10/ (has a bit about gibMacOS as well as creating a USB MacOS installer under Windows), https://www.tonymacx86.com/threads/...to-download-macos-directly-from-apple.295248/
One method of creating MacOS USB under Windows - https://pureinfotech.com/create-macos-bootable-usb-windows/
  • Like
Reactions: smr
smr
smr
OP
6 Mar 2008
Leicestershire
Thanks, I've got a bootable Monteray USB so I'm just trying to format the drive in recovery mode. When running these commands:
First command successful, second says "You cannot manually format an existing APFS Container disk"
3 Jun 2005
The South
Try deleting the containers first (iirc you can't do the entire disk with deleteVolume so you'll have to enumerate through each container with /disk0s1, /disk0s2), eg -
Code:
sudo diskutil apfs deleteVolume /dev/disk0s1
As always, make sure you list your drives and volumes/partitions/containers (etc) beforehand as they can change from startup to startup.
smr
smr
OP
6 Mar 2008
Leicestershire
ok so I've used the code
Code:
on all instances of the disks - disk0/0s1 etc. through to disk 3
and
Code:
diskutil apfs deleteContainer diskX etc.
Then I've tried to erase disk3 and it says You cannot manually format an existing APFS Container disk
smr
smr
OP
6 Mar 2008
Leicestershire
update - so I've actually got so exasperated I've removed the screen and plugged the SSD into my Windows Computer. I tried deleting the partitions with Easeus partition master but even that wouldn't run without errors so the only thing I can do is Wipe the disk with Easeus which I am doing at the moment.
smr
smr
OP
6 Mar 2008
Leicestershire
Thanks for the help anyway.
Ordered a new Hard Drive. As I thought it's knackered. Could not get it to format even after wiping it with Easeus.
smr
smr
OP
6 Mar 2008
Leicestershire
I've installed the new SSD and gone to erase it - the options show Mac OS Extended, ExFat etc. but not APFS, isn't APFS needed for SSDs to run optimised ?
smr
smr
OP
6 Mar 2008
Leicestershire
it's ok! I plugged the usb in I made the other day and it started disk util in an old format with no apfs option. removed it and did Internet Recovery and it's got APFS available.
