Capping Off Unwanted Electrical Cables
29 Sep 2004
Wilt of the Shire
I'm going to change my room thermostat tomorrow. The current one has Live, Switched Live & Neutral. The new one doesn't need neutral or an earth so do I need to cap them off with something or can I just tape it and leave it in the wall?
You will need to disconnect the neutral or it will trip the rcd constantly
How's that? Because it's floating alongside the live?
As for OP typically I've seen earth and neutral left in a terminal block to insulate them, you could use Wagos if you need it smaller. But I'm curious about the above also.
Aye, IIRC it shouldn't trip the RCD if the neutral is properly insulated, as there isn't any current loss you're just effectively turning it from something that needed an incoming power separate from the switching side, to something that is acting like a light switch and going between the "live" and the "switched live" returning to the controller/boiler.
Thanks for all the info.
I've seen the wago's but they only seem to be sold in packs and I only need one. However, just to be clear, if I put the wire into one of these and tuck it away in the box it will be fine?
another vote for wago .
or not seriously..........when we moved in years ago the old owner had used sellotape i kid you not shocking (literally)
Thanks all for your help, job done.
Room temp shows 17.5 on the stat but on a Therm Pro I have it shows 14.5, guess I'll only know if it's working right when heating comes on later.
The heating now seems to be working better since I changed the thermostat, it turns off when the room temp is reached which it never did before. One thing I have noticed though is that the thermostat clicks several times an hour but the timer is off. Is this normal? I don't seem to recall the old analogue thermostat doing this.
It's always handy to have some Wago's at home, you can grab smaller amounts from sellers on eBay. I paid £5 for 10 x dual and £6 for 10 x triple delivered.
I fitted a Tado about a year ago and it came with some rubber sleeves to slip over 1-1.5mm wire to similar effect, terminating any unneeded wires.
