t-cutThat’ll buff right out.
The pilot are strapped to the seat when they eject. The seat has the parachute built into it AFAIKDoes the seat have it's own parachute?
If not then it could ruin someones day!
Get a nice watch from Martin Baker if you eject!F35 next generation crashing machine.
Bit of a judgement call ejecting lol looks silly afterwards.
And the US Army is planning to replace their Blackhawk fleet with a version of the Osprey, that tilt wing mess which has killed more US Marines than the Iraqis did.
Thanks for the info, I thought it was strange that the Pilot ejected.Is it a watch? - it used to be just a tie pin.
Also - the F35 actually has an auto-eject function whereby under certain circumstances it will bang the pilot out without even asking nicely first.
Auto-Eject - As the F-35B has two sources of thrust, each producing 20KN of thrust, whilst in the hover (the engine via the nozzle at the rear and the lift fan just behind the cockpit) if the lift fan fails during a hover the 20KN thrust from the engine nozzle at the rear would "flip" the F-35 nose down (like a cart wheel) faster than a human could react to eject safely hence the auto-eject function.
It works by comparing the three FCS channels together with each channel being fed 3-axis rotational rates, linear accelerations etc from two separate Inertial Measurement Units, making six units in total. Should two channels (or 4 measurement units) all agree that the nose down pitch rate has exceeded a minimum of 20°/sec, a figure higher than a pilot in a "serviceable" F-35 could ever manage, the the Auto-Eject sequence is initiated and there is no delay between the decision to eject (by the FCS comparison) and the initiation signal so, should a lift fan fail, the seat will not "wait until the aircraft is level" etc before ejecting, within milliseconds of the decision being made the seat is already leaving the aircraft so the crash footage does not show an auto-ejection sequence taking place.
...we've seen a 30 sec video and now folks will post whatever they want, but some of the stuff (not just in here TBH) regarding the F-35 is just wrong...
Surely at that point it was probably more dangerous to eject and not have the chute open properly than just wait it out
Got to be a difficult decision because you know there's a good chance you'll hurt yourself ejecting on the ground.
Are the pilots not strapped into the seats?Adding an extra chute to save the seat as well is considered not worth the weight penalty. The test seats do have them though.
[/QUOTE
Ejection Tie Club - Martin Baker
martin-baker.com
Why do you think the chute wouldn't open? They have zero-zero ejection seats. I'd rather eject than wait to see if the fuel is going to ignite and burn me to death.Surely at that point it was probably more dangerous to eject and not have the chute open properly than just wait it out
Because I didn't realise zero zero seats were a thing and I've learnt something new today.Why do you think the chute wouldn't open? They have zero-zero ejection seats.
