- 12 Feb 2006
- Surrey
We have a baxi 800 gas boiler and Drayton wiser smart system, with their smart TRVs on every radiator.
Even when every radiator is set to off (verified through the app) and the hot water off, the boiler is still firing up and pumping.
The only radiator that gets hot is the one in the bathroom is it's always open, however it doesn't have a trv and no other radiator gets hot because they are all closed and not requesting the boiler to be pumping heat to them.
It's fairly new boiler at 3 years.
Any ideas what could be causing the issue? It's located in the loft. Is there perhaps a safety feature where it runs if the space that the boiler is in is below a certain temperature, so that it doesn't freeze?
The only way to get the boiler to go off and spray off is to switch the power off to it
