We have an induction hob. Two rings stopped working so bought a new one. Prior, they all worked fine, which is key to my dilemma….
It is hard wired to a 32A isolator with a single L/N/E wire.
I bought a replacement and was confused when it came with a wiring loom consisting of L(brown) / L (black) / E / N.
Bit odd but saw the old hob had L2 and N2 connectors with nothing on so just went ahead and wired it up. Powered up but only two burners worked…. Odd considering that’s what just happened to the old one.
Now I think this might just be one big huge coincidence and the new unit is faulty, but am I missing anything? I’ve looked at a number of new ones many of which all have this wiring.
I can’t use a 13A plug version as I don’t have anywhere to plug in and will need to use my existing wiring, so that’s not an option.
What is this mysterious second live for and do I HAVE to have it wired up (how!?). Or is it likely to just be a huge coincidence this new hob has the same fault as the old one?
Thanks!
Thanks!
