Can I get this unit finished this week? That's the main question...
So I had an hour and was like **** it, let's knock out some welding and you know what? Sometimes it comes out and I look after and I'm like, I'll take that ****!!
It won't win any awards, and ignore the splattering, too
but still... then the next one is a bag of aids, so you know... grinding disk is my friend.
Anyway, I got welding all together the last frame piece at the bottom. I brought it all upstairs and pieced it together to see how it was coming together and I'm super pleased.
Here's the drawing vs. where it is now to show how it's coming on:
And here is a pic of how it looks.
Only had an hour, so could do what I could do.
On my list now:
- Grind down welds, make prettier
- Weld all 3 frame pieces together
- Grind those then down
- Weld on 4 legs to sides, with mesh behind
- Grind those welds down
- Paint Hammerite Black smooth
- epoxy in all 3d printed caps
- install bottom shelves
- Attach hardware (hinge/ fitting) for doors
- Attach top to base
I think I should be able to have all this done by the weekend. That's the idea anyway. I always aim to get too much done, but without the kids here, I think I can work some in the evenings as well to knock bits out.
I got notification that my router bit will be some time, which is annoying, so either way, will be good to get this off the books.
