It only happens when CPU boost is active (at least, when I tested it, it seemed fine for hours with CPU boost off).
I'm just gonna check if it could be related to a setting I turned off weeks ago, called PSS (on ASRock boards). This changes how CPPC works, which determines how cores spread out the load across the available cores. I turned this off before, because I thought it would be better to spread out the load more evenly across each core.
