I'm not a huge fan of the SolaX app so i've been playing around with a raspberryPi zero to pull stats down every 5min, log them in a database and then combine in a pretty basic javascript page (heavy lifting on the client side):
Top bar is the reload timer, SolaX apis only update every 5min which is annoying, apparently theres a way to get a direct line to the inverter so that may be a next step...
Icons are current mains drain (daily total isn't accurate so zero at the moment), battery % and drain/charge, Solar Power current and total (when the login turns up) and current weather (need the wind gusts for chicken's cover which needs taking down over 40mph)
1st graph (with historic date selector) shows Green is battery usage, light blue area is battery %, orange grid usage, red battery charging (from grid/solar), yellow daylight hours & blue line cloud cover %.
Under that is hourly weather for the day, 2nd graph tomorrows cloud cover & tomorrows weather:
Next job is to add historic power usage from bright / glowmarkt but its lags by about 14hrs
