So my boiler broke down just after the cold snap and I had a plumber come out to look this morning, he got it up and running again and pointed out that there was a lot of air in the system and almost no pressure, after getting the pressure back up and the system running he left and got on with his day. Several hours later and I notice one of my kitchen worktops was covered in water, closer inspection revealed that water was leaking from around a plug socket and there was also a noticeable damp patch above said socket at the ceiling, the pressure in the system was down to about .3 bar from 1.5ish when the plumber left.
The system comprises of a Potterton Promax SL15 boiler which is in the kitchen but on the opposite side to the leak, the pipes we think run over the ceiling and back down into the cylinder, there are a couple of radiators above and near to the leak but they both appear to be good and no wetness can be felt. There is no header tank as it's a mains fed system and all the pipework is speedfit plastic other than the copper piping in the cylinder cupboard.
Now, assuming there is a split pipe or knackered joint somewhere how much of a pita is it going to be to firstly locate and secondly fix? Am I looking at bedroom/bathroom floors needing to be lifted or will any fitting be accessible somehow rather than hidden away by the final stages of construction?
