love how crusty those buns look against the juicy cheesy dripping patties nomBloody hooge home made burgers and home made crusty bun..
Imagine the size of a big mac, then multiply it several times, then yeah.
I need a lay down for several days now, or possible hospitalization for being a greedy ****
I had a cheeky one tonight.My burger eating ability is getting poor lately. I was terribly full after finishing a big tasty last night
Those cheese melts are on another levelI had a cheeky one tonight.
Did you do the fresh burger trick?I had a cheeky one tonight.
Yep, removed Tomato and extra lettuce.Did you do the fresh burger trick?
And the burger was not dry?Yep, removed Tomato and extra lettuce.
I remove them too, and no, the sauce keeps it moistAnd the burger was not dry?
??Yep, removed Tomato and extra lettuce.
Even with sauce the meat was super dry when I had it lastI remove them too, and no, the sauce keeps it moist
had clearly been sat there for decades
Customise the burger at McDonalds to get a freshly made one rather than one that's only fit for use as carpet underlay (even underlay is softer).
As above, the sauce is good, for the record I ADD extra lettuce.And the burger was not dry?
You can do it via the app, just customise the item you are ordering.Ahh I only use the app to order
I’d never get extra lettuce when it’s delivered. The burger always turns up a right mess.As above, the sauce is good, for the record I ADD extra lettuce.
But the meat itself? Nicely cooked? Not dry?As above, the sauce is good, for the record I ADD extra lettuce.
