Security Incident December 2022 Update - LastPass - The LastPass Blog
Please refer to the latest article for updated information.nbs[..]
I moved from lastpass and Google authenticator and consolidated everything to Bitwarden and Authy. Very easy to keep things synced across PC and mobiles devices and the UIs seem perfectly functional to me.
Please refer to the latest article for updated information.nbs[..]blog.lastpass.com
So all the password data has been accessed but it's still encrypted. So, just a case of brute forcing and catching out the weak ones then?
Time to move elsewhere it seems, my master password (random symbols and 15+ words) and other passwords are fairly solid but I feel a need to cycle through and change everything on the back of this 2nd incident.
Just an FYI if you didn't know, Bitwarden premium can generate your 2FA codes.
Write them down on sticky notes and put them on the monitor.
Are there any viable alternatives that are more resilient to hacking?
I would say the only really secure option is hosting your own, but it'll have it's limitations for working remotely (outside the home). Your best bet really is setting up a VPN in this instance rather than opening ports/port forwarding.
Problem with this is you always have to go through the VPN. Will be a pain IMO if you don't always don't need to be on it. I use Caddy web server and it sits behind a reverse proxy. I accept not everyone will be able to do this option so just hosting it with BitWarden is the only choice for most.
When I check my logs I do have attempts but nobody is getting in as it's got 2FA attached to the account.
Yep you've gotta make a compromise somewhere between being secure and ease of use. IMO you're better off having it hosted by Bitwarden and having secure passwords with 2FA.
I'm thinking of moving to Bitwarden premium. £10 is negligible.I would say £10 a year is an absolute bargain and I personally think BitWarden is one of the best ones out there.
I don't have the skills or patience to host my own and make it effective enough.
You lost me at reverse proxies.£10 works out at roughly 0.027 pence per day.
It's about a pint and 1/4 in London lol
You need working knowledge of web servers, security, reverse proxies, ssl certs and domain configuration to get it working properly. Then there's mail settings so that it emails you when there's a log in or anything else it needs to email you about. I have it connected to an SMTP server and sign up is disabled because you can allow multiple people to use the service with a log in. It's pretty funky.
I've moved from LastPass to Dashlane to Bitwarden and now to 1Password.
I love the UI and integration across browsers/devices, having different vaults shared between family members we can all contribute to including having policies/documents in there for easy access for all, and they've fairly recently partnered with Fastmail where it'll generate a masked email for you when signing up to websites (I already use domain/[email protected] anyway, but it's a nice way to move the identity away from @mydomain.com if needed).
Anyone defending LastPass needs to reread the article and extent of the breach.
Personal Data and URLs were taken in an unencrypted form. This makes weaponising the breach so much easier and more potent.
The update also states the source code and other data stolen would have allowed futher exploitation and access to and decryption of cloud data.
Its generally accepted that data gets stolen, and as long as you used a strong master password the encrypted data lost isn't likely to be decrypted. Getting unencrypted data taken which can be used in phising and other attacks to decrypt the encrypted data is shocking.
Data loss aside there is a Privacy Question to ask - LastPass states they had a Zero Knowledge environment. They dont. (They have a readable list of all your services saved in their vault)
