- 29 Sep 2020
I have Samsung Odyssey G7 monitor capable of 165hz at 4k
12900k@ stock .What CPU do you run?
I have 4 x 8gb DDR4 running at 3200mhzWhat is your memory speed?
Yes - cores are alternatively at 100% and just a few %What is usage like on each CPU core? Is there like one or 2 being maxed with all the rest at basically zero by any chance?
If you've got a couple of cores at 100% with others at less than 10 and overall just 30% usage then you are CPU bottlenecking - you'll have to see if there are any tips for getting Forza to use more cores.Yes - cores are alternatively at 100% and just a few %
When I swapped a 3090 for a 4090, I still had global Vsync on in the Nvidia control panel settings (for best G-sync results)
I forgot to turn it off when benchmarking Forza 5 and it was limiting me to 120 fps at 4k (because my LG G2 OLED is 120hz)
Could it be that?
My next check is that its getting enough power. I put in a new corsair 1000hxi psu and made sure there were 4 pci-e cables feeding power but will check they were all seated correctly and also try another connecting cable (fasgear one from amazon).
