- 14 Jun 2004
- Newcastle U/T
hey all,
Been a while since I looked at these and when we moved I couldn't find the original Thermostat so had to leave my hive behind.
The new setup is:
Combi: Ideal Logic H15
Controller: Therma TQX0027
Stat x2: Therma TQX0073 (one for downstairs and one for bedrooms)
Water Tank: Evocyl 18L EVO HO STD 2Z (immersion OFF! lol)
The controller and stats are woeful compared to the Hive system we had, also have no idea when stuffs on or how the house is keeping temp!
I'm a little confused as to what the correct install should be for this and got great help on here last time
Woudl I be correct in assuming that the install route I need is a Hive for Combi and then an additional stat?
This would be 1 hub connected to the router but 2 receivers connected to the boiler I think?
Annoyingly I've confirmed the new build lot have said that all the controllers and stats are hard wired :/
The new setup is:
you just have a system boiler (also known as heat-only, hence the H in the model designator).
