Is it possible to use US appliances in UK?
Example, device which states 15 amps, 120V. Can this appliance be safely plugged into a UK 240V standard wall outlet and used with a US > UK adapter without a transformer?
The device is a '10lb Electric Wax Melter for Candle Making by Bare Botanics | Heat Resistant Handle & Brass Spout | Made in USA'
I connected this without a transformer and with a wattage measuring plug also connected and it said 'overload' instantly which means over 3500 Watts. My guess is the wattage was fine, but the voltage was double
If it keeps tripping or starts to get hot it's not beefy enough. Electro-wind are reputable, they have wound me some custom stuff and they are helpful. But site transformers abound on Ebay, or ask at the local gypsy site...
