Hi all. I have been following this overall situation quite keenly - being an owner of the Sapphire 7900 XTX (MBA). Firstly, at stock settings on the card I do count myself somewhat fortunate that I don't have the outright TJ Temp on it hitting 110*C nor power draw throttling as soon as I go in to any game or such (its traditionally orientated in my Fractal Torrent case, with the 2*240mm fans at the bottom acting as intake to supply cooler air (as the front intake has my H150i also set as intake mind you).
However I can't help but feel a bit concerned for the performance of this card in the warmer months where at the moment I am seeing TJ Temps top out at 87-95/96 degrees when under 100% load hitting boost clocks (2.5k mhz) (with the GPU at 57-64*C - so a Delta of around 30-35*C?! - Is that even normal?! -
Id be interested to see what others may get in this respect).
Are we going to see potential latent issues down the line if there is an issue with the vapor chamber in accordance with
Debauers findings per the video he posted today. Whilst not apparent in my cards case now, is it otherwise an issue awaiting to manifest later. Where do we then stand now with this in mind (RMA now? Will they even accept it as a pre-emptive - would OCUK even potentially entertain an exchange (my MBA card for a AIB card and pay the diff?!) - starting to wish I had perhaps waited for the AIB Custom cards and paid a bit more and avoided this 'doubt' first time around.
