Deleted User 298457
Deleted User 298457
Hi folks,
I've spent some time considering my options for 'fixing' the pretty dark and cramped kitchen. Since removing the boiler I've been scratching my head on what to do with the weird space that has been left as a result.
I've also understood a bit better what the previous owner did. When they added the rear "Lobby" (utility room) they moved the kitchen wall from the yellow highlighted area back to where it is indicated on the floor plan. The door opens into the slant of the stairs (i.e. max 90 degrees opening). The worktop without the sink is precisely 600mm and it has zero margin for error otherwise it fouls the door frame. Diagram:
Now Plan A is to win the lottery (and move) and knock the lobby down, create a gigantic wraparound extension and have a wicked kitchen diner. Unfortunately the cost is probably going to be outrageous unless I sell a kidney.
Cue thinking about plan B, C, D,..... J....Z.. and I think I have found a solution. Diagram:
N.b. I despise "kitchen diners" and I hated the idea of having a living room plus kitchen diner (personal preference). This is a compromise on not achieving Plan A but not spending crazy amounts of money on interim solutions.
So key features...
* Doorway into kitchen is blocked off. Path to the kitchen is via dining room, through living room, hook a left into the kitchen.
* Wall removed (approx. 1100mm without allowing for whatever wall needs to be left to hold the steal) with 1600mm of wall removed so that the new kitchen cupboards provide "the back" for the sofa.
* New cabinets along wall where door was bricked up to get so me of the space back.
Something roughly right, but where the table is would be where my sofa is:
Plan A is always the answer but costs are so high at the moment, it'll be 5-7 years down the line. I reckon I could do an IKEA/DIY Kitchen pretty inexpensively. It also removes one of the worst features for a modern buyer in a 1930s house at the lowest cost, and we keep the lobby for the washer/dryer avoiding the biggest grumble I have with open plan spaces.
Thoughts? How much is a steal for a span like that (~2.7m)?
So key features...
