Huawei S7-721W mediapad 7 youth 2 tablet - Firmware
25 Jul 2009
England
Hi,
I have a Huawei S7-721W mediapad 7 youth 2 tablet which I need to put the firmware on a SD card to get the tablet back up and running.
The links I have either don't work anymore or are the websites that want me to signup to download and look extremely sketchy.
According to google the device should have android jelly bean 4.3
Does anyone know where I could possibly get the file from?
Try here
Only one I could find
Though says region is phillipines
Not sure if that will cause any issues though sounds like
It's not going to make it any worse anyway
Only started the download
I didn't complete it and see if it's what it says it is
Are there no recovery options?
Press power button + volume down button together
Least I think it's something like that
Been a while since I messed around with tablet roms and stuff
Yeah I ignored ones wanting you to jump through hoops
To be able to download
Hopefully Huawei help you out
In the meantime I would suggest xda developers forum
As probably the best bet
Above firmware link for S7-721w 4.3 B002 do not have UK region but only phillipines region.
Try download HiSuite software to download and update your tablet firmware?
