We have similar issues and a ridiculous duct run to the outside in the attic rood. Would an option be an extractor through the wall straight to the outside?
Where do you put your dehumidifier, Bug One?Just get a dehumidifier. It really is the simplest solution. You'll only need it during winter.
I've created a routine for ours now, so it comes on and goes off automatically after half an hour whenever we have a shower.
I had problems with a dripping vent last year. Mine was uninsulated. Over the summer I replaced it with insulated ducting and shortened the route it was exiting. Mixed with running the dehumidifier, haven't had any problems this year.
I've just got mine in a space in the corner of the bathroom. I bought a relatively compact one specifically so that it would fit in there. It's wired loosely, but neatly under the skirting from a socket I added specifically for this purpose in an adjoining room. The bath is very rarely used. If I were to use it (for muddy dogs) I'd move the humidifier.Where do you put your dehumidifier, Bug One?
I have a lot of issues with humidity, in my bathroom, and bought a really powerful (though expensive) dehumidifier.
Works really well but I could not work out how best to use it.
At first, I tried putting it actually in my bathroom, after a shower, and it completely dries everything really quickly - this is not practical, however, long term.
I then tried leaving the device on in the middle of the house (and set it to keep humidity constantly at no more than 60%) and leaving the door wide open - this works pretty well, as it keeps the whole house dry, but I am now thinking of trying to leaving it just outside the bathroom door (and again just leaving the door wide open after a shower).
Thanks for that - great idea. I think I might move mine, just outside the bathroom to prevent as much humidity spilling into the rest of the house.I've just got mine in a space in the corner of the bathroom. I bought a relatively compact one specifically so that it would fit in there. It's wired loosely, but neatly under the skirting from a socket I added specifically for this purpose in an adjoining room. The bath is very rarely used. If I were to use it (for muddy dogs) I'd move the humidifier.
Come March, it'll go back into storage until next winter. I did the work to incorporate this along with revisions to the inline ducting last summer after having issues with condensation last winter.
Would it be easy to wire up a fan like this to a PIR? I feel like that is going to be the best way to go about it I don't want to wire it in to a light circuit directly.I fitted this exact inline fan back in 2015 and have it set to run for roughly 15 minutes after the bathroom light is turned off
(think i set it to the middle speed setting but can't remember for sure)
You maybe better off asking an electrician or starting a new thread on here and asking someone that knows more about this then me..Would it be easy to wire up a fan like this to a PIR? I feel like that is going to be the best way to go about it I don't want to wire it in to a light circuit directly.
