Version 4.6.5
Added new MSI Windows 11 themed skins (Light and Dark editions) by Drerex design
Added voltage control for reference design AMD RADEON RX 6700 XT series graphics cards
Added experimental support for Intel 11th generation CPUs
Added experimental support for Intel 12th generation CPUs
Added experimental support for mobile AMD Ryzen CPUs
Fixed issue with missing memory temperature sensor on AMD RADEON 5700 / 5700 XT series graphics cards
Fixed issue which could prevent MSI Afterburner from opening from tray via main application icon after accessing properties via clicking monitoring tray icon
Increased memory overclocking limit for NVIDIA GeForce RTX 30x0 series graphics cards
Added workaround for internal DirectInput issue, which could cause hotkey handler to stop processing hotkeys correctly after locking/unlocking PC from keyboard with <Ctrl>+<Alt>+<Del> or <Win>+<L>. To bypass it MSI Afterburner is resetting hotkey handler state after lock screen transition now
Optimized monitoring profiles switching implementation for situations when profiles contain different sets of data sources displayed in monitoring tray icons
Application tray icon is DPI aware now:
OS level tray icons scaling is disabled now to prevent tray icon text distortion. Power users may revert back to the previous DPI unaware tray icon rendering mode via configuration file if necessary
Added new bigger tray icon fonts for >=150% and >=200% DPI scaling ratios. Power users may also select tray icon font independently of selected DPI scaling ratio via configuration file if necessary
Application installer is DPI aware now
RivaTuner Statistics Server has been upgraded to v7.3.3
					www.guru3d.com
				MSI Afterburner 4.6.6 (final) Download
MSI Afterburner 4.6.6 download - Guru3D and MSI have been working hard on AfterBurner, we released an updated Beta revision of Afterburner; this application successfully secured the leading position on graphics card utilities in relation to monitoring and tweaking. We are the only official...
