First gaming pc are these specs good
13 Jan 2023
United Kingdom
Case
PCS PRISM TG BLACK ARGB MID TOWER CASE
Processor (CPU)
AMD Ryzen 9 5900X 12 Core CPU (3.7GHz-4.8GHz/70MB CACHE/AM4)
Motherboard
ASUS® ROG STRIX B550-F GAMING WIFI II (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Memory (RAM)
32GB Corsair VENGEANCE DDR4 3200MHz (1 x 32GB)
Graphics Card
12GB NVIDIA GEFORCE RTX 4070 Ti - HDMI, DP, LHR
1st M.2 SSD Drive
1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
1st Storage Drive
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
Power Supply
CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable
1 x 1.5 Metre UK Power Cable (Kettle Lead)
Processor Cooling
Corsair iCUE H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Network Card
10/100/1000 GIGABIT LAN PORT
USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System
Windows 11 Home 64 Bit - inc. Single Licence [KUK-00003]
Operating System Language
United Kingdom - English Language
Windows Recovery Media
Windows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account
Office Software
FREE 30 Day Trial of Microsoft 365® (Operating System Required)
Anti-Virus
Norton 360 For Gamers: 1 User, 3 Devices - 1 Year Subscription
Browser
Firefox™
Warranty
3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Nothing fundamentally wrong with the specs but always comes down to cost and are there better options.
If you are going for an AM4 gaming pc then you are better off getting 5800X 3D rather than the 5900x. Mobo is ok but the ram says 1x32 ? If that means you are going to have 1 stick of 32gb of ram and not 2x16gb then it will destroy performance by only being single channel. GPU is ok for price , all newly released gpus are over priced so no good options. Storage is ok but dont know prices. PSU is not the best of corsairs range. AIO is expensive but looks nice.
Obviously I can work out it is a prebuilt and where it is from , dont say it is against forum rules, but you can say how much it is going to cost and then see if OCUK can do a better deal with their prebuilts.
The choices you have are.
1- Stick with AM4 and if you do I would suggest 5800X 3D is better option than 5900x
2- Go Intel 13th gen , 13600k 13700k would be very good system and can go for DDR5 with those. May come to more money.
3- Go for AM5 , 7600 is just out and gives great performance at low power. Also 7700x and soon to be 7800X 3D which could be the best gaming cpu for next year but best to wait for reviews.
I would strongly suggest you wait for reviews of 7800X 3D before you buy the above system.
Things you can tell us to help is cost of above system and what res and refresh rate your monitor is.
That one was £2.2k and I’ll be getting a new monitor that will be 165hz and 4ms
Here is an AM5 self-build for comparison:
Thermaltake Toughpower GEN5 GF3 1000W Fully Modular ATX 3.0 80 Plus Gold Power Supply - £199.99
Lian Li Lancool II Mesh C performance Midi-Tower Case - Black - £104.99
Arctic Liquid Freezer II High Performance CPU Water Cooler - 360mm - £119.99
WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T3X0E) - £159.95
AMD Ryzen 7 7700 Eight Core 5.30GHz (Socket AM5) Processor - Retail - £338.98
Asus TUF Gaming B650-Plus WIFI (Socket AM5) DDR5 ATX Motherboard - £242.99
TeamGroup Vulcan 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (FLBD532G5600HC36BDC01) - £139.99
Asus GeForce RTX 4070Ti TUF Gaming 12GB GDDR6X PCI-Express Graphics Card - £899.99
Grand Total: £2,222.77 (including delivery)
Alternative 1700 self-build with 4080 (PSU & SSD as above):
Lian Li Lancool 205M Mesh Micro-ATX PC Case Black - £69.95
Cooler Master MasterLiquid Lite 240 AIO CPU Cooler - 240mm - £56.99
Intel Core i5-12400 2.50GHz (Alder Lake) Socket LGA1700 Processor - Retail - £199.99 (price placeholder, swap for i5-13400F)
Asus Prime B760M-A WIFI D4 (LGA 1700) DDR4 Micro-ATX Motherboard - £171.98
Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-25600C18 3600MHz Dual Channel Kit (CMK32GX4M2D3600C18) - £89.99
Palit GeForce RTX 4080 GameRock OmniBlack 16GB GDDR6X PCI-Express Graphics Card - £1,249.99
Grand Total: £2,211.13 (including delivery)
You did not let us know the resolution. Is it 1080p 1440p 3440x1440, 4K. Obviously it is a high refresh rate monitor so you want high fps but knowing the resolution is more important than refresh rate.
Would also be good to know what games you play. If a bit of everything that is fine but if you play Warzone 2 24/7 then AMD have a clear advantage, if it is Cyberpunk with RT then Nv has clear advantage.
The builds above by Tetras are good so you can see it is a minefield of choices if you are able to self build.
Sorry it is 3440x1440 and I’ll be playing cod, rust, destiny 2, the cycle frontier, mc and generally games like that
Which prebuilt is this I can’t see it
Here is an OCUK prebuild so you can see how much cheaper it is to self build.
My basket at OcUK:
  • 1 x OcUK Tech Labs AMD 7000 Series "Zen4" Pro Gaming PC Configurator (SKU: FS-1G9-OG) = £2,572.73
    • Cases: 1 x Phanteks Eclipse G500A D-RGB Mid-tower PC case - Satin Black
    • CPU: 1 x AMD Ryzen 5 7600X Six Core 4.50GHz (Socket AM5) Processor - Tray
    • Motherboard: 1 x Asus TUF Gaming B650-Plus WIFI (Socket AM5) DDR5 ATX Motherboard
    • Memory: 1 x Corsair Vengeance EXPO 32GB (2X16GB) DDR5 PC5-44800C36 5600MHz Dual Channel Kit - Black (CMK32GX5M2B5600Z36)
    • CPU Cooler: 1 x Arctic Liquid Freezer II A-RGB High Performance CPU Water Cooler - 240mm
    • Graphics Card: 1 x *Build* Asus GeForce RTX 4070Ti TUF Gaming OC 12GB GDDR6X Graphics Card
    • Power Supply: 1 x Seasonic Focus GX-1000 White 80 Plus Gold Power Supply
    • Primary M.2 Solid State Drive: 1 x WD Black SN770 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T3X0E)
    • 2.5" SATA Storage SSD: 1 x WD Blue SA510 1TB SSD 2.5" SATA Solid State Drive (WDS100T3B0A)
    • Operating System: 1 x Microsoft Windows 11 Home 64-Bit DVD - OEM (KW9-00632)
Total: £2,586.83 (includes delivery: £14.10)​
This is similar to the AM5 build Tetras did above but as you can see it is at least £200 more expensive even if you left out Win11. All quality components so nothing to worry about there.
My basket at OcUK:
Thanks for the recommendation
Hi could you make one with a budget around £2000 that’s still good if don’t mind
Yes we can make up a prebuild with a budget of £2000 that would be "good" but good is a subjective term and it is not possible to make a prebuild with the OCUK configurators and still have a 4070ti in it. GPU is most important part of a gaming PC and whilst the 4070ti is overpriced (imho) it is still the cheapest of the so far released new generation of gpus from NV and AMD.
So if I say 2500 is that okay?
If you took this build and removed Win11 , you caninstal that yourself for less money it would come to under that budget.
You could also remove one of the SSDs , I am not sure what your storage requirements are but the original build you posted has 1tb M.2 drive and 2 TB HDD. I personally will never use traditional spinning disc HDDs again but I know some people still do for mass storage needs.
My basket at OcUK:
Click on the link and have a play with the configurator , see what options are available.
Thanks mate, will this still be good if went for ryzen 7?
