Hello All,
Got a strange issue with my SH5, the SH5 is nearly a year old.
The issue is with the 2.4ghz channel, The 5ghz channel is fine and has no issues even when this problem is happening.
The issue:
The 2.4ghz channel will just suddenly stop broadcasting.
After trying to resolve the issue it will randomly start working again and be fine for while without any issues then it will drop out again.
This effects 3 x phones and 1 x tablet as these are not wifi 6 devices they can only connect to the 2.4ghz channel, when this happens the 5ghz channel is fine (TVs\laptops connect to this and have internet).
I have these channels separated and connect devices to the supported channel.
I have tried the following
- Changing wifi name
- Disabling and re enabling the wifi channel
- Factory reset the SH5
- Turned the SH5 off for 5 mins
Is there anything else worth trying?
I do not have a wifi router to put the SH5 in to modem mode but I have been considering this route, Can anyone suggest a wifi 6 router that I can separate the channels on?
The issue:
