new PC, games unstable
20 Oct 2002
Oxfordshire / Bucks
I have stress tested with prime 95 and 3D mark, no problems
Also did the Furmark GPU test , again no problems
Games on the other hand are crashing back to desktop
Elite dangerous for example, running Ultra quality on 1440p @ 165Hz
2 mins in, crash
not sure if i should post this in hardware section or here, but like i said, stress testing seems fine
specs:
7600X (AM5)
2x 16Gb Corsair Vengeance EXPO 6000
Radeon 5700 XT
m.2 ssd
1000W PSU (brand new phantecks Pro)
windows 10 64
found this on AMD community forums
  • AI Tweaker in ASUS or Advanced->AMD Overclocking
  • Precision Boost Overdrive (Advanced if through AMD overclocking menu)
  • CPU Boost Clock Override = Enabled(Negative)
  • Max CPU Boost Clock Override (-) = 200
i will try this
Can you run the memory one stick at a time to test? Less likely to be one or an incompatibility between them than two sticks being faulty.
