- 19 Oct 2010
I'm gonna rooll the dice today then and use some grid from -4 to -1 before 17:00 and see what happens. I've got a historical baseline of zero units in the 17:00 to 18:00 window.
Well for the past week I've used next to nothing in the afternoons thanks to good solar and storage - so will this affect me? Or is it worth shoving the batteries on charge for an hour or so before the session?
Will be really interesting to see your "savings" in that case.
I calculated my usage is 1.6kwh average over last 10 working days. That will be zero today, so any other affecting number will come from -4 to -1 usage.
I will grab the data off octopus tomorrow and wait for the calcs to come in end of the week.
We dont really have enough data so you like john_smith would be a good base case.
Its -4 to -1 hours though (1-4pm) so don't charge after 4 its too late![]()
) from that time and just take a hit - if it works out to cost me more than I save, I'll just cry in the corner.
Givenergy bloke is here having a fiddle around, should be back online later today. V1 or V2?
Gen 1![]()
Have you got a source for this part since I couldn't find it on the NG stuff.
If this is how its working the in day adjustment is more significant than the history data which would seem a bit odd.
Im not sure.
The main factor is supposed to be the savings in the session itself. See above on what 94JDH says, I'm not sure if thats right or not, I can't find where NG specifically say how they make the adjustment.
Gen 1![]()
Sorry I was driving so couldn't reply earlier.Yeah I posted it above with link to doc, its still potentially slightly murky due to some iffy terminology, but its clearish.
You just missed the adjustment for the baseline. Clarifies its an amount added though and not a % impact.
Well its in and going through calibration! Good to have it back now anyway!
Yes the baseline is an adjustment but for me and others running from batteries probably doesn't influence it.
If I remember the two hour session in December I used 36 kWh and was paid just over £53.
36/6 = 6kWh half hour average multiplied by 4 ( as it was 2 hours saving session) = 24kWh.
This multiplied by £2.25/kWh = £54.
So it's about there, what it's saying is longer saving sessions are more beneficial.
and as Hippo says to hax a savings session.
