- 4 Aug 2007
- Wilds of suffolk
Do you have Solax as well, thats the result that I see as well, a massive jump in SOC. Although for me its consistent at around 73-74%, it then jumps to 99% over about 10 minutes and settles to 100% soon after.
Initially I thought it was other issues, but when I saw a day when the batteries charged at 5.5kwh for about 1hr 40 I went huh!?
I checked and it was the same constantly, they never draw enough power to be able to provide the 11kwh they are supposed to. (System is 12.3kwh but 11 useable due to DOD)
It seems the actual output is around 8.4kwh (give or take), but with input around 9.2(ish). So the conversion loss is about right especially if as i suspect they are, they are heating a bit. There is supposed to be a setting I am told, but can't find it for battery heating on/off.
I will get some serial plates photos today to see if i can work out exactly what the batteries are, manu dates etc. Since I believe Solax did an older version of 3.1kwh and well as a newer one.
I had kind of given up getting anywhere in the short term with the temps being blamed for the battery performance, but it seems the batteries are sitting well above zero constantly now after I added insulation and nothing is any differernt.
Delving into the specs a bit more it looks like with battery heating on they should work down to -30, with it off they will draw down to -10, but only charge if above zero.
I was assuming I was going to have to wait until March time to get some decentish temps overnight so they could stop blaming the temps.
I know there will be some effect from temps, but this just seems to consistent when temps are varying by like 15c between when it was installed and the coldest point since installation.
None of this really to me explains the big gap though since it seems to be constant. (Quoted vs actual performance)
The thing they ignore every single time I try to question is that a 3 battery system quotes useable battery of 8.4kwh, basically smack bang on what I am getting, but they refuse to entertain that something is up and I could only be running on 3. Based on the fact the system can see 4.
I also get a similar dramatic line when it gets to around 25%, with I think no more than 0.4kwh being delivered from the batteries between 25% and 10%.
I am going to try to nag Solax UK some more.
