- 2 May 2011
- Woking
16C is the minimum recommended temperature for any room, unoccupied or otherwise.
Your use of the word immediate is a pretty big pointer as to why 16 is recommended to maintain, not ZOMG NEVER HIT 15 heheI can understand this for occupied rooms for health reasons. But for unoccupied it seems excessive. You're not going to immediately get damp issues and mould growing at 15 degrees as opposed to 16!
How anyone can live with rooms heated to 24c is beyond me.
We have no issue reheating our house, we let temps drop down overnight to around 12-14 degrees (down to 11 the last few nights!), we can have the heating on then for 1.5hours tops and the whole house is back over 17 comfortably.It's more to do with the building materials, and then also reheating time.
You say that, but it entirely depends on the house. Ours is at 20c all day and 18c overnight and we used exactly the same amount of gas as you in December. Plus, try telling that to my partner who would complain she's dying at anything less than 19.Anyone running at 18-21 all day long is just burning money for no need.
Crikey. I used 2433.57kwh in December and it barely got above 17 more than once!We have no issue reheating our house, we let temps drop down overnight to around 12-14 degrees (down to 11 the last few nights!), we can have the heating on then for 1.5hours tops and the whole house is back over 17 comfortably.
We used 1040kwh gas in december and are likely to use similar if not a little less in January. We are a 3 bed semi with myself WFH and my wife and sister in law childminding from the property as well.
Humidity levels are close to the upper end of whats considered acceptable but still 65% or below.
Anyone running at 18-21 all day long is just burning money for no need. We used to have the house mostly at 20 degrees in previous years and this year we are now comfortable at much less than this. Hot water bottles and heated blankets have made for much cosier evenings as well, silver linings and all!
Yeah i would happily run the house warmer if it was more efficient to do so but its an old 1950's build and not very well insulated so we live with what we have. However you do get used to the colder temps, on average this year we are 4-5 degrees cooler and the only real appreciable difference is wearing jumpers and slippers.You say that, but it entirely depends on the house. Ours is at 20c all day and 18c overnight and we used exactly the same amount of gas as you in December. Plus, try telling that to my partner who would complain she's dying at anything less than 19.
Is that just Gas or Gas and electric, mine was just gas.Crikey. I used 2433.57kwh in December and it barely got above 17 more than once!
You wouldn't compare gas and electric in kWh terms would you?Is that just Gas or Gas and electric, mine was just gas.
Yes you would? It's literally the unit your energy company charges on.You wouldn't compare gas and electric in kWh terms would you?
Yeah at different rates. A pound is a pound but a kWh of leccy doesn't dump the same amount of heat into the home as a kWh of gas. And even if they did it would cost you a different amount.Yes you would? It's literally the unit your energy company charges on.
People pay different rates, even on the price cap, which is exactly why you should be comparing kWh usage. It's the only direct comparison.Yeah at different rates. A pound is a pound but a kWh of leccy doesn't dump the same amount of heat into the home as a kWh of gas. And even if they did it would cost you a different amount.
Surely the only sensible comparison between gas/electric/mixed is how much it's costing?
