Hi after a bit of advice, my pc spec is in my sig and I'm already running a Dell 27 Gaming Monitor: S2721DGFA.
Basically I'm going to retire the mobo/cpu/ram/GPU to a secondary PC, with a cheap case and PSU...so I'm looking for basically just a core system - mobo, cpu, GPU and RAM.
I was thinking of building something around an i5 13600k. I'd rather run aircooling rather than liquid, probably a big fat Noctua or Thermalright assasin.
and i'd like the ability to overclock. I'll probably throw in a 1 TB m.2 drive also, WD blue or simmilar? as i'm running a bunch of older SATA SSDs at the moment.
GPU wise im looking at the 6700xt but unsure if it's worth spending a bit more.
I don't do much hard core production work, so anything built around gaming will be plenty powerfull enough for any of that stuff I might want to do.
Shold I look at an i7? or an AMD ryzen... the i5 seems pretty good for its price point?GPU wise im looking at the 6700xt but unsure if it's worth spending a bit more.
