5 year old Seasonic Focus Plus 850W Platinum Modular PSU, still good for a 4080 build?
6 Jun 2005
Plymouth / Cambridge
Hi,
i am specking out a new build after 10 years, with the new build total currently at 3.5k i am looking to save money where i can. sadly the GPU is eating all my budget ( :mad: Nvidia). i curently have a 850W Seasonic PSU in my system, at the time i bought (2018) it it was overkill but only £100 then.
my new build on PC partpicker adds up to 635 watts total with a 4080. Can i use my old 850 PSU when everything is on full load? would this be a safe thing to do or should i buy a new 1000W PSU? using my existing PSU would save me £300.
Thanks
Paul
Hi,
Thanks
Paul
You'll be fine, power spiking not too bad on 4080.
It's a solid PSU with a ten year warranty and lots of built in circuit protection... that's why you buy a good PSU in the first place... it costs a bit more but it's good for 10yrs+
Thank you all for your comments, using this will really help keep the cost down.
What is your full build?
at present its this, subject to change though
Lian Li O11 Air Mini - Black
Ryzen 9 7900X3D
Kingston FURY Beast RGB 64GB (2x32GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit (KF556C40BBAK2-64)
Gigabyte GeForce RTX 4080 / RTX 4080 founders edition
my existing 850W Seasonic PSU
NZXT Kraken Z63 AIO CPU Water Cooler with LCD Screen - 280mm
Asus ROG Strix B650E-E Gaming WIFI (Socket AM5)
Samsung 990 Pro 2TB M.2 2280 PCI-e 4.0 x4 NVMe 1.3c Solid State Drive
Noctua NF-A12x25 PWM - Black x5 (optional)
Noctua NF-A14 iPPC-2000 x2 (optional)
NZXT RGB & Fan Controller
Ryzen 9 7900X3D
Cheaper drives that are just as good as the 990 Pro. Look at WD's X models. https://www.overclockers.co.uk/wd-b...rive-with-heatsink-wds200t2xhe-hd-594-wd.html
Also do you really need such an expensive AIO? You pay an awful lot more just for a screen with no added performance.
In that case, there shouldn't be any living drives in my house :D
They fill them with inert gas...
/back to topic. If they lose power abruptly its double bad, system may corrupt / hardware may damage, if you are just nvme/ssd its just its single bad.
I'm not saying it is a good idea to keep doing it (and I know it was a big issue with early SSDs), but I'm pretty sure they test them for this nowadays and the drives are not supposed to just brick themselves anymore. Samsung talk a little about it here.
